Yestday I noticed that once I came to a stop, pushed down the clutch pedal and put it in 1st gear, the car would surge a little bit. Today I noticed it does the same in reverse. So I tried putting it in 1st with the clutch all the way down and reving the motor a bit.
The car started to move forward very slowly! It does the same thing in reverse also!!! Is there any way that the clutch would not disengage all the way? What should I check?
I appreciate any advise or comments, as I am stumped!
-David
1999 Contour SVT
K&N Air Filter Kit
Redline MTL fluid
