#963225 05/25/04 06:24 PM
N
N
Ok so i realize that this is a stupid question but where is the ecu harness i cant find it for anything. and is the wiring diffrent than the safc 1?
1998.5 SVT Contour silver frost Intake, Exhaust, 20% mirror all around, 18" ALT stanima wheels, Eibach's, B&M short throw, 9mm ford racing wires, SAFC II, oem carbonfiber hood, MSDS headers, Panasonic head unit and one alpine 10".
#963226 05/25/04 07:45 PM
It's behind the P/S reservoir exactly where the PCM is mounted.
The majority of the wiring is the same between the two.
The only real difference for us is the S-AFC II has a smaller display and does not look as good. (both display and unit)
I personally would recommend the S-AFC over the S-AFC II. It is cheaper, does the exact same thing, and has a much better display and controls.
The whole arguement over 8 NE points, 12 points, 40 points, 1000 points, etc is all pointless.
The PCM itself only uses 10 points and can generate a perfectly flat A/F curve. The stock spacing is between 500-1000rpm.
Any extra changes are just ignored because the rpm climbs past them so fast they are rendered moot.
Think of it this way.
4 seconds to go through 6000rpm - 1500rpm per second
4 seconds to go through 4000rpm - 1000rpm per second
6 seconds to go through 3000rpm - 500rpm per second
That's 0-90mph or "almost" the 1/4 mile for most folks.
#963227 05/27/04 09:41 PM
N
N
Ok so have another question. I instaled the safc on tuesday and now i dont know if it is because of the unit or something else but every 4 or 5 seconds my car just revs up around 500 rpm at idle and then you can feel it rev even while i am driving. any help would be greatly appreciated
And i know that it is a hotwire maf but after that it has a screen that has in and out and then numbers underneth them. what do i need to set those numbers at?
#963228 05/28/04 02:40 PM
Should be in 1 out 1.
All the pertinent info is in the How-To I wrote.
And like I said in the PM I sent you the thing shouldn't be doing ANYTHING funky to your idle with the settings set at zero on the air adjustments!
