well i got my motor torn all the way down to the short block with it in the car. i am doing a 3 angle valve job and doing a 30degree back cut on my valves, replacing valve seals, replacing 4 (so far) broken valve guides, blending the bowls and opening the throats, doing some port matching and resurfacing the heads at work. I work in the cylinder head dept. at a machine shop so basically im getting the works for the price of parts.
my question is while i have the motor this far apart should i go ahead and take the pistons and rods out and replace my rings and bearings. if the bearings are not bad and i try to reinstall them will they fail because of being disturbed. and if the bearings are worn will i be able to install new standard size bearings w/out getting the crank ground.
(the motor has had a rough life being overheated due to broken w/p w/ previous owner)
i don't plan on keeping the car for a very long time but i want to fix it right so that when i do sell it im not worried about passing along a lemon like i bought.
oh and im doing all the headwork just becuz i can
i mean who can be against free hp
