#962605 05/25/04 01:00 AM
Ok so I have decided to order the Koni adjustables with the Eibach pro-kit. My question is should I get the Camber/caster adjustable plates now, and what else if anything should I get to make the installtion go as easy as possible. I work at a Porsche Dealership and my buddy whos a tech there works on Fords alot and he an I are going to install them. Just want to make sure that I have everything and am able to go through with the installation. Oh and I am ordering the kit from shox.com for 785 for the konis and eibachs, it says it fits contours 95-2001, but I thought that the suspension was a little different between the <97, and the 98<. Can someone verify that this kit will indeed fit, I have a 98 Eo SVT. Thanks
Griffin
98 silver CSVT (EO) TOTALLED 99 Honda Prelude 5 spd....much to come!!!!
#962606 05/25/04 03:58 AM
It will fit. When you get 98+ springs and 98+ struts, you can use it on any year.
#962607 05/25/04 05:30 AM
If you think it is likely that you will need to adjust the camber with the new springs (very likely), you should get the adjusters now. Otherwise you will have a lot of duplicate labor. The front struts must be removed from the car and the springs removed from the struts to install the kits.
