#961879 05/24/04 02:01 AM
There doesn't seem to be many with this problem based on my searches.
Is my only option to replace the factory foam gasket that seals the taillight/reflector assembly to the trunk lid? I tried caulking around the front of the back up lights where the electric connectors are and sealed up any holes I found. Water still gets in. This is a pain because when I open the trunk, the water comes dribbling out onto my groceries.
'98 LS MTX
#961880 05/24/04 06:46 AM
I had the exact same problem on my '98 LS. There is a little hole in the bulb 'receptacle' that allows water to leak in from above.
I can't remember off hand how much you need to remove to get at the back of the assembly. I'll check this morning when I get home and post back. You'll need some silicone to plug the hole up.
Bless our servicemen & women overseas. L.Cpl Ian Malone, 1st Battalion Irish Guards, R.I.P.
#961881 05/25/04 01:21 AM
I have the reflector off now. Back when I fixed the license plate screws I caulked the holes you are talking about. I still get the water though.
'98 LS MTX
#961882 05/25/04 01:42 AM
My cure was to reinforce the whole reflector assembly area around the plate area with thick foam tape. This held up for 2-3 years but the inherent crappy design has let the water work its way through again. I just keep a stash of extra reverse bulbs on-hand and replace them as they rust out. I had a pic of my fix somewhere but I can't find it at the moment.
Sorry I can't be more specific, HTH
-Peter
(also of VT)
04 Mazda 6s V6 MTX, in service 10/28/03 02 Subaru Impreza Outback Sport 165HP 4cyl auto AWD former: 95 Mystique LS V6 MTX [11/14/94-5/19/04]
