Posts: 682 |
The new old Tour I bought seems to have a low-temperature thermostat in it, or maybe a jammed one: the gauge barely gets up to the bottom of the mormal range. So my question is, to those of you who buy low temperature thermostats on purpose: how high does the gauge go, and is the bottom of the normal range on the dial too low?
It doesn't help that this car's automatic fan switch is broken, and some goober put in a manual switch for the radiator fan, instead of fixing it. To be safe, I mostly leave it on. Better too cold than too hot.
Posts: 2,975 |
I've got a 180 deg Stant Thermo. Since that install and new coolant and flush I never got over R but never stayed at the N mark for long periods of time. Can't say it's bad but neither can I say nothing is wrong.
1992 Ford Escort LX-E
-Tracer LTS spoiler
-GT Grille
CEG road warrior
CEG road warrior
Posts: 17,248 |
My gauge will stay around O......in traffic on a hot day it will get up to R....soon as I start going....back to O.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 682 |
I think I've got a stuck-open thermostat... running so cold that if it was winter the defogger wouldn't be working. I remember what that was like on the shytti old Mazda 6 I had once, where somebody put it back together with no thermostat at all...
Speaking of parts being left out, I found that somebody left the brake pad retaining clip off my left front wheel. This is good because I thought I needed new brakes but it was just the caliper occasionally rubbing the inside of the wheel due to the lack of the spring.
Another thing going on with my cooling system is somebody put a manual switch on the radiator fan instead of repairing the automatic switch.
Lots of little things wrong, but I got it for a third of what I thought my car replacement budget was going to have to be.
Just replaced the driver side mirror. Now I just have to paint it so the sides match... probably end up steel-wooling the passenger side one and spraying it black. It's scuffed anyway.
Posts: 2,483 |
170 t-stat and oil cooler, needle never passes the "N".
Frank McCoy aka Mod-deth aka Mid Life Crisis aka SVT Doood aka mcgainer is a SCAM ARTIST
Pre98 Zetec - Some Mods
Posts: 21,653 |
I have a 180 and I don't go above the O in normal driving. In winter, I sometimes didn't even get into normal range on way to school. I have added some redline water wetter and now, when the t-stat opens at 180 when doing aggressive or slow driving the temp actually drops back down unlike it used to. My low speed fan has worked only once since I've owned the car, so I can't idle for long or the engine gets real hot and the high speed won't kick in until it gets out of the normal range.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 3,465 |
Originally posted by LoCoZ: My gauge will stay around O......in traffic on a hot day it will get up to R....soon as I start going....back to O.
what he said
2003 Subaru WRX some mods
Even if you don't have the answer, you certainly have to admire the problem.
aka ZetecRacing
Posts: 3,335 |
I have a 180 and it usually doesnt go above 180 (aftermarket guage). When it had the 195 and the OEM guage, I would sit at the L.
· Jon Miconi
· Coming Soon!
· 01 Cougar
· 98 V70R
Posts: 495 |
I've got a 170 and the needle is still in the same spot as stock, but with a OBDII monitor hooked up, it shows around 170F at highway speeds. I like it.
2000 Rio Red I4 Cougar
200whp & 210wtq at 9psi
254whp & 276wtq with NX 35shot
WRX TD04 Turbo, Cut Short Shifter, Strut Tower Bar, 17" ZN Wheels, Roush Springs, Starion Intercooler, NX 35 shot, HKS SS BOV, Full 3" exhaust,StreetFlight Chip
Posts: 1,085 |
Test your Temp sender, test your gauge........
2012 Lotus Evora
95 Mystique MTX - GONE 395,000 Kms
--------- Both Zetecs
'97 Contour Mtx - stock - GONE
