#958404 05/20/04 01:11 AM
When my gas gets aroung a 1/4 of a tank I can not go above 4 or 5 rpm's is this a problem or does the contour have something that save gas so it does not let you go in a high rpm. Any feed back will be helpful thanks
00 svt contour black B&M shifter
#958405 05/20/04 01:18 AM
Mine is doing the EXACT same thing. I think my fuel pump is going out.
"Eagles may soar high, but weasels don't get sucked into jet engines."
#958406 05/20/04 01:36 AM
IIRC, the fuel pump has two different inlets, and the lower one (aka below 3/8 or 1/4 tank) can get clogged pretty easily, making it harder to draw the fuel up from the lower inlet. A new sock filter(if you can find a sock sold seperately from the pump, anymore) will fix this...
Ray
#958407 05/20/04 02:05 AM
LOL - 5 RPMs??? That is certainly not normal and I'd venture to say that would even be lower than a Harley chugging away at idle. Normal idle is around 750 RPMs.
Wisecracks aside, mine doesn't do that. I can run it up to redline regardless of the fuel level until I'm out of gas.
#958408 05/21/04 04:06 AM
Well my is still under waranty so i'll just take it in now thanks
