Posts: 26 |
I get a loud pop, or bang, on a regular basis when backing up and turning the steering wheel. Very common when making a 3 pt turn, and backing out of a driveway. I pulled on the tie rods, and all is tight. Any ideas.
Posts: 4,639 |
what kind of pop. i get a pop more when its cold and seems like its the ebrake releasing when i put it in reverse and start backing up.
Hugo AIM:omegazodiac
Posts: 80 |
In the past when my frontend has had this problem, it was either a bad cv axle or my subframe was loose. My recomendation would be to check both. See if there is and cv grease anywhere, possible cv boot torn, when it dries out the cv joint is usually the next thing to go bad. hope this helps.
"Not a newbie" Been here since it all started!!
98 silver SVT Contour
several mods and counting
www.pickettperformance.com
"Remember, you're part of the human race, try not to embarrass the rest of us"
b0x @dm1n
b0x @dm1n
Posts: 4,397 |
Mine does this when I back up after using the hand brake and particularly when the car is parked with the nose pointing up and incline. Often the hand brake doesn't release all the way until the rotors move. They bind!
-Andy
Andy W.
The problem with America is stupidity.
I'm not saying there should be a capital punishment
for stupidity, but why don't we just take the safety
labels off of everything and let the problem solve itself?
Posts: 3,506 |
Sounds like a CV joint gone bad, or a tierod.
Check both out...look for axle grease on the subframe.
But thats been my experience if i hear a poping noise in my front end.
Lupe
Posts: 26 |
Thanks for the posts. I'll see what I can find out over the weekend. I can certainly say it's not the handbrake, I had that problem earlier as well!
Posts: 3,345 |
When I had a popping in my front end it was caused by the sway bar link, the one that goes from the sway bar to the strut. Got that replaced and had no troubles after.  Well not from that part anyway.
1996 MM
Zetec, ATX
192000 kms...not dead, but I'm not fixing it
White people love Wayne Brady because he makes Bryant Gumbel look like Malcolm X.
Posts: 140 |
I had the same problem. I replaced the front strut bearings and its gone now. I suspect the upper spring moving in the strut seating...but who knows.
