Posts: 55 |
Whats all involved in installing a solenoid pack? Dunno spelling on solenoid but its for my transmission sorry kinda newbieish dunno where it even is......... someone told me my solenoid pack must be acting up once they felt my tranny problem..........
Posts: 2,017 |
Originally posted by fordhater: Whats all involved in installing a solenoid pack? Dunno spelling on solenoid but its for my transmission sorry kinda newbieish dunno where it even is......... someone told me my solenoid pack must be acting up once they felt my tranny problem..........
To answer this question please state year of car, ATX or MTX and engine size.
1996 2.5LT V6 Contour ATX My Tour+help/info pics
E0 rims, Gutted Pre-Cats,CTA Custom Exhaust & Intake, Diablo Chip.
Posts: 55 |
1995 ford contour zetec (2.0 I4) automatic transmission
Posts: 2,017 |
from what I can find out it's inside the tranny. part #11 Valve body Solenoid The solenoid valve body assembly contains the transmission fluid temperature (TFT) sensor, as well as five powertrain control module (PCM)-controlled output devices: electronic pressure control (EPC) solenoid shift solenoid No. 1 (SS1) sift solenoid No. 2 (SS2) 3-2 timing/coast clutch solenoid (3-2 T/CCS) torque converter clutch (TCC) solenoid
Posts: 1,176 |
I'd move this post to the transmission forum and unisys can give you all the details.
Posts: 24 |
Remove you battery tray and battery. remove you valve body body cover (pan) -its right there embedded in your VB. A couple hour job-I am currently doing a VB swap and shift kit install-will have some pics up and a write up done in a week or so.
Posts: 55 |
Originally posted by actionpaintball: Remove you battery tray and battery. remove you valve body body cover (pan) -its right there embedded in your VB. A couple hour job-I am currently doing a VB swap and shift kit install-will have some pics up and a write up done in a week or so.
Do you know how its embedded in there will I need to take a screw driver along or a wrench or does it like pop out?
Posts: 1,176 |
You've spent more time on this message than it will take you to replace it!
