I
I
how do you get the heat shield off under the car? thanks.
2004 Pontiac GTO Bush 2004
Y
Y
Hey there are like 6-8 nuts that hold it on... The right socket will fit around them although they don't look like they really take a socket(Don't remember what size).. But take those off and then pull it out..
Mark
b0x @dm1n
b0x @dm1n
Um why do you need to get under there for the shifter install?
-Andy
Andy W. The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
I
I
Because I have a 2000 and it is a different install. You have to install a plate under the car but I have it installed and it is awesome.
Are you saying you don't have to do anything under the car if you are installing a short shifter on a 98 SVT? (I ask because I may eventually get one)
98' Contour SVT #607 of 6535 05' Mazda 6s Audio/Visual enthusiast because it's one of the many things I went through 4 years of hell for
I
I
They're two different plates. Mine was huge and goes under the car and the 98's and 99's go somewhere around the shift tower.
Y
Y
Yes, as I found out the 2000 model has a different style shifter tower than the earlier model cable shifter towers.. The earlier models need a smaller plate that basically raises the actual shifter tower up almost 1/4" where as on the 2000 model, you need to take out the foam lining that is accessible from under the car and put a plate there in it's place.. The foam actually went up into the car, so the Steeda having the longer base would make the shifter cable rub.. The plate that I made for mine gave the clearance I needed..
Mark
