#953015 05/11/04 06:10 PM
Nis-Firing on Multiple cylinders
99 Ford Contour ATX Zetec
New wires, plugs MAF put back in original coil. Any ideas???
www.ChicagoCEG.com 2006 White Grand Prix
#953016 05/14/04 12:20 AM
Replaced injectors today, still no go. She runs but misses like crazy still.
#953017 05/14/04 12:35 AM
Use an inductive timing light to check the regularity of spark for each plug. If you are truly missing spark randomly, try the crank and cam sensors.
You may also want to check compression. A blown head gasket will do that.
#953018 05/14/04 02:51 AM
Yeah, just got back in from playing with it and no luck. I was trying to check for vacuum leaks.
The CEL actually was flashing before it stayed on constantly and you can feel the mis-firing while driving.
All this started when my Intake bypass hose disconnected fron the intake manifold, I figured I burnt out injectors or something from the car running too lean but now i know thats not the problem anymore.
#953019 05/16/04 02:14 AM
I
I
check your ignition system. spark plugs and wires and check the coil pack. my car did that also. the shop i took it to replaced the plugs but it didnt fix it. so check the wires and coil pack
96 Contour GL I4 hasnt been on the road for a year, tranny problems. nuf said
#953020 05/16/04 06:47 PM
i had the same code a few months ago and it ended up that some wires by the uim were burnt thru and i had bare wires. i had one helllll of a miss! i hope this helps
2006 fusion sel 1998 grand prix gtp(wife) 1993 dodge shadow es(winter beater)
#953021 05/17/04 11:00 PM
Thanks guys. I'm just about out of ideas now. Plugs and wires are new, switched injectors. Stil missing. Man I need to get this thing fixed soon!
