Page 2 of 2 1 2
N
N
Originally posted by fordhater:
.......seems like the tranny is acting up it happens when it gets heated up.........It shifts all over the placce causeing intense jolting.........so Reconditioned drive axle $60....... Used Trannsmission if i pull it myself $100........
I would first try the drain and fill method first with cheapo ATX fluid. It could also be the TCS sensor ($30). There is no garantee that the tranny you pull will be in any better shape.
engine leaks oil very slowly........
Probably needs new valve cover gaskets, where exactly is the oil coming from?
blower motor is shot........clunking noise coming from suspension when I hit bumps (i think its a loose bolt on the stabilizing bar tho again)
Get a used blower motor from the junk yard. The clunk could be the sub-frame bushings, the endlinks, struts, ball joints, or the CV joint. Hard to tell without being there.
'95 Mystique ATX I4 2.0 134,000mi '96 Contour MTX I4 2.0 36,000mi My Rides
I agree, it would be cheap to try some new tranny fluid. If it makes it run better, put some good fluid in and a better tranny cooler and go
-Ken V. 1998.5 SE Praire Tan Zetec ATX psycho_bass@hotmail.com Roush springs Roush rear sway bar BAT struts 17" Millie Miglia HT3 and a ton of subtle asthetic mods
F
F
I dont have a tranny cooler I dont think....only thing its hooked up to is the radiator I also put some transeal in the tranny cause i thought it had a leak but doesn't that stuff I'm skeptical about it smelt like fuel injector cleaner....I'm hoping to god this is going to be a easy fix I can currently go from school to work and work to home without 1 problem which makes me feel so good cause it hopefully wont be internal its only when the car is driving for more than 15 mins it will jolt/downshift/upshift/jump out of gear and back in.... somthing that tells it what gear to go into is most likly shot i hope.... If not I can drive from school to work and to home and just no joyriding anymore....
well can you afford to buy another car? do u like your car?
NEED AN SVT REAR BUMPER!!! pm me
that's a good point. don't go and sell your parts or anything if you can't get another.
96 contour gl columbus ohio
Page 2 of 2 1 2
