Posts: 375 |
so where do i put the jack-stands when doing the rear? i have looked and can't find a good spot.
also is it ABSOLUTELY necessay to bleed the clutch after i bleed the brakes?
Alex T.
98.5 Silver Frost CSVT #5510
05 Nissan Frontier Nismo 4x4 6 speed
85 Bronco II 6" lift 302 swap
Posts: 3,496 |
In front of the rear tires and to the inside of the jack point cap on the rear is a place in the corner that is part of the subframe assembly. It works well for the jack stands.
Posts: 375 |
nobody knows about the clutch question??
Alex T.
Posts: 4,693 |
Originally posted by slolx50: nobody knows about the clutch question??
Usually not. It is a good idea to change the clutch fluid from time to time though, just like you chould change the brake fluid from time to time.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 375 |
thanks for clearing that up jim.
Alex T.
Posts: 3,335 |
Ive always put the jackstands on the metal that holds the lateral control arms. Provides a wide enough spacing to keep the car quite stable as well.
· Jon Miconi
· Coming Soon!
· 01 Cougar
· 98 V70R
b0x @dm1n
b0x @dm1n
Posts: 4,397 |
That will work but can be a little unstable. The rear jack points are better!
-Andy
Andy W.
The problem with America is stupidity.
I'm not saying there should be a capital punishment
for stupidity, but why don't we just take the safety
labels off of everything and let the problem solve itself?
