Posts: 21 |
I bought an alternator filter to filter out the alternator noise. Can anyone tell me where the alternator is located and which/what color wire I need to put the filter on? Any help will be greatly appreciated.
Don LaReaux 2000 Contour SE Nakamichi 40z HU Kicker i570 (front) Stock (rear) 2 10" JL subs Memphis 16-ST500D (500rms)amp Rockford 160.2 pushin the front Kickers
Posts: 1,032 |
Is this a typical noise filter, or an actual "alternator filter"?
If it's a regular noise filter (which it probably is), you just wire it in-line on your amp's power cable. It should also have a ground, which you should appropriately ground.
1999 SVT #900/2760 Born on 1-20-99 Silver Frost/Midnight Blue A few aesthetic and audio mods
Posts: 21 |
This is an alternator filter. It has two wires. I bought it from crutchfield.
Posts: 1,032 |
Did you buy the "PAC ANS-80 In-line Alternator Noise Filter"?
The alternator is a small generator run off the accessory belt in the engine compartment. Splice it into the power wire coming off of the alternator.
I can't tell whether or not it needs to be grounded. Just make sure to follow the supplied instructions on the wiring.
Posts: 21 |
Where exactly is the alternator located and what color would the power wire be?
Posts: 21 |
Oh yeah....it is the PAC ANS-80 In-line Alternator Noise Filter from crutchfield.
Posts: 1,032 |
It's on the left side of the engine compartment and a PITA to get to. Your best bet is to get a Chilton's manual instead of me trying to explain how to hook it up. You don't want to put it on your starter or something and let a bunch of electrical gremlins loose on your car.
They've got pictures and specific diagrams, a big help.
Posts: 21 |
Yeah I hear ya. Ill get one of those manuals before I try. I appreciate the responses, no doubt!! If I feel its gonna be to hard I wont do it although I dont think it'll be that hard. Thnx again.
Posts: 65 |
I believe if its a pac filter you hook it up to your RCA jacks running from you pre outs and then connect the cables to it. The alternator has nothing to do with the hookup Brian Originally posted by Macmadd: I bought an alternator filter to filter out the alternator noise. Can anyone tell me where the alternator is located and which/what color wire I need to put the filter on? Any help will be greatly appreciated.
2000 SVT Green KKM True Rev Pioneer 6200 Head Unit Rockford 800a2/600a4 amps Infinity kappa's/Polk 12" dx128 subs Short throw shifter/Voodoo Knob ADR Revolution Rims Toyo T1S 215/45/17 Bassani Cat Back
Next Mod: SHO Y PIPE/Diablo Chip
