I was wondering whether or not I could use one of those APC Air Breather Filter things in place of my 2.5L's PCV Tube?
That tube that is located near the front of the engine that goes from the valve cover to the air box, and is mostly consealed underneath the water pump cover, has fallen apart on me and broke in two places.
I checked all the local wreckers and they don't have any. I also called Ford and they want $30(Canadian) for a new one!
So, correct me if I am wrong, but isn't that tube basically useless? I'm 99% sure that all it does is insure that the small amount of vacuum that is present at the valve cover connection is always sucking-in clean air, and that's why the other end is connected past the air cleaner/filter. So if I just took the tube off and replaced it with an Air Breather Filter, wouldn't that just do the exact same thing??
If you're not sure what an APC Air Breather looks like, go to
www.4apc.net and select "Filters" and then just scroll down...
Anyone have any input?
THANKS!:)
