Posts: 205 |
Would it be possible to fit subs in the rear deck? I need to preserve trunk space, that's the only reason I ask...
92 Talon TSi AWD
DSM= Daily Scheduled Maintenence
Posts: 3,076 |
Do a search
2000 SVT Black/Tan #1633/2150 (a few mods)
Alpine: CDA-9835, MRV-F540, MRD-M550
PG: TANTRUM-X 6.5 COMP all around.
Some people wear Superman pajamas. Superman wears Chuck Norris pajamas.
CEL currently: Off
Posts: 8,301 |
-Ken V.
psycho_bass@hotmail.com
Posts: 205 |
Man, i guess I'm just using the search engine wrong... it never comes up with a dang thing I search for...  Thanks for the links though
92 Talon TSi AWD
Posts: 1,359 |
Of course it is possible...
98' Contour SVT
#607 of 6535
05' Mazda 6s
Audio/Visual enthusiast because it's one of the many things I went through 4 years of hell for
Posts: 9 |
Were there any mods that had to be made in order to fit the sub in the rear deck?
Grn 99 Contour Sport. Pioneer DEH-P6000 head unit
Posts: 1,359 |
Well, the hole opening in the rear deack is only about 5.75" in diameter. So depending on what size speaker you want to mount, you will most likely want to enlarge the hole. Some people in the past have just left the hole the size that it is and mounted the sub to a piece of wood with a larger hole (cut to the diameter of the speaker cone).
98' Contour SVT
#607 of 6535
05' Mazda 6s
Posts: 1,423 |
My messy install, but preserved trunk space. As mentioned, a piece of wood with a larger diameter hole cut out works.
I feel Guilty, Oh so guilty
Posts: 4,789 |
The hole size need not be increased for an 8" sub, a typical grille will have less space to allow air through than the stock hole.
-Mitch Hedberg
