Originally posted by wht94cobra:
OK. So I need two separate wire kits? One for the radio and one for the Amp?
You could just order the kit from crutchfield for $20. It comes with both wiring harnesses. One is for power, ground, power antenna, etc... and the other is for the speakers which hooks up after the stock amp (hence, amp bypass). It also comes with the DIN removal tools.
You'll save yourself some headaches of running to a bunch of different places, possibly not getting the right stuff. The directions are very helpful too for a novice installer.
You'll have to put in your radio's mounting collar, which is easy. Do your wiring (the stock amp is behind the glove box), slide the stereo in, and listen to your new and improved tunes.
