This is from my Service Manual
Vibration, roughness, shimmy, and thump may be caused by excessive tire or wheel runout, worn or cupped tires, or wheel and tire imbalance. These conditions may also be caused by rough road surfaces. Drive the vehicle on different road surfaces to determine whether the surfaces are actually the cause of the condition.
Do not immediately suspect the tires or wheels when attempting to diagnose a vibration problem. Other sources of vibration include:
Loose or worn wheel bearings
Loose or worn suspension or steering components
Worn upper front suspension bearing and seal
Worn or damaged front wheel driveshaft joints
Front disc brake rotor or brake drum runout
Loose engine or transaxle supports
Engine-driven accessories
Start with checking that your tires have the right pressure in them.
1996 2.5LT V6 Contour ATX
My Tour+help/info pics
E0 rims, Gutted Pre-Cats,CTA Custom Exhaust & Intake, Diablo Chip.
