It was my vehicle-I would buy a replacement AC compressor and swap them out. I believe you can remove your compressor and buy the shorter belt-but I will warn you that you should cap your old lines-in the future if you ever want to go back the other way (sell the car etcâ?¦) You can pick up a reasonably priced compressor off ebay or
www.car-parts.com. I would strongly suggest using the OEM set-up, getting a new belt and leaving it at that. If you are worried about the compressor failing again-you can always pull the AC relay under the hood and the compressor will never lock up again.
Good luckâ?¦
