Posts: 80 |
Alas, the time has come to sell the SVT. I was planning on getting a miata and making a project car out of it. There are loads of engines to fit, but I was thinking about a 2.0l zetec. I just wanted to get some facts straight, and I know there's no better place than here!  I keep hearing the zetec can take an insane amount of compression, as well as operate in the 13k rpm range with upgraded valve springs. is this true? I basically want to take it, modify the bellhousing a little so it can take a T5 and change the rear around on the car a little, then mate the engine with a t3/t4 (something like this but a little less costly). could I actually get a zetec to produce +300hp?? if so, what else am I missing here? thanks guys!
I ran a search already!
99 Ford Contour SVT - SOLD!!
'90 CRX Si, '98 Explorer V8, '98 Acura ITRally Co-Driver
Posts: 21,653 |
NO! Don't put a zetec into a miata. The zetec is great, and can get 300hp fairly easy with a turbo setup BUT, it's not worth dropping into a miata. The miata engine can take boost easier than a zetec can. Or you can drop a 302 in or a couple of other engines. I've seen a supercharged miata at the drag strip and no way would I waste the time putting a zetec in after seeing that thing fly down the strip. Heck, even a 3L duratec has been put in a miata, I'm sure you could do that if you want, but it wouldn't leave a lot of room for a turbo or anything else.
Also, not sure about revving to 13k rpm maybe in a strict race engine in a lightweight race car, like a formula ford not a miata.
Anyways, to sum it up, don't use a zetec in a miata, it would be a waste of time when the miata has a perfectly good engine in it already.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 8,301 |
I agree with Kremi. The 302 would be my choice. Although a 351W is the same size, with more displacement....  Or mabye a 347 stroker...  Then turbo that. BTW, revving to 13K is cool, but higher revving engines like that have very little to NO torque on the low end. I bet it wouldnt be very drivable, if thats what you wanted to do with it. I wish you luck with whatever you decide to do though. And be sure to post pics when its done
-Ken V.
psycho_bass@hotmail.com
Posts: 80 |
man, zetec guys tellin me not to use a zetec. no wonder there aren't any posts in here  well, I don't want to put in a duratec because me and the duratec have a not-so-happy history (remember, I have an SVT) and it's a bit of a squeeze. the 302 is way too big, and I'm pretty sure it's gonna throw the balance off quite a bit. I was wanting to use the 2.0 cause it was lighter. I'm tryin to keep the balance as close to 50/50 as I can. also if I'm correct, the 1.6 & 1.8s can't handle near the boost a zetec can. oh yea, and I wasn't planning on creating a 13k rpm engine which produces no torque, just wanting to confirm that fact. I'll keep after the miata forum too and see what they have to say. thanks!
Posts: 21,653 |
I'm pretty sure you could do a 302 conversion and have a good balance, you can do it in a focus, so probably can in a miata. The miata engines STOCK were made for small amounts of boost. A friend of mine ran ~10psi daily on a stock miata engine and ran 14psi for a while until he totalled it. They can handle more power than you think. Hit up the miata forums and you'll see.
98.5 SVT
Posts: 80 |
oh yea, and supercharging is definately not out of the question. if it's feasible to super a zetec to 300~350ish, I'd do it, cause the super'd miata engines are only pulling 190 @ the wheel. not to mention I'm tryin to pull originality points here.
Posts: 21,653 |
they may be putting 190 to the wheels, but at what psi? I promise you the one I saw at the strip was a miata 4cyl engine with jackson racing supercharger pushing a lotta boost and it was flying, more than 190hp flying. Though they brought it in on a trailer, it was a street/strip car judging by interior and what was in the trunk. I mean they built it to be fast and not drive it every single day, but still drive it on street sometimes.
98.5 SVT
Posts: 2,975 |
Originally posted by imnotted: not to mention I'm tryin to pull originality points here.
And I know at least I would praise you for just the notion of doing it
1992 Ford Escort LX-E
-Tracer LTS spoiler
-GT Grille
Posts: 8,143 |
if you're gonna go FI I don't see why a zetec wouldn't be an option.
But I don't know if the zetec can handle 300HP on stock internals...now if you were shooting for 200HP then go for it.
But I thought the stock miata engines were good on their own?
Posts: 21,653 |
Originally posted by ZetecNinja: But I thought the stock miata engines were good on their own?
They are, that's why I'm so against him using a zetec in a miata.
98.5 SVT
