Posts: 1,660 |
Originally posted by harrup: Thanks, Scott
I will do it. Where is the switch located?
It's that push button you referenced two posts up. There's only one screw in it. Remove the screw and the whole thing will fall out. Just be sure that after you disconnect the wire it doesn't fall back into the body, it's a bear to fish back out.
Scott
Troll! '99 BMW 328i
Posts: 195 |
Originally posted by Pigeon: ... Just be sure that after you disconnect the wire it doesn't fall back into the body, it's a bear to fish back out.
Scott
Are you speaking from experience?
2000 T-Red SVT, #562/2150
Posts: 1,660 |
Originally posted by musicnut: Originally posted by Pigeon: ... Just be sure that after you disconnect the wire it doesn't fall back into the body, it's a bear to fish back out.
Scott
Thankfully, no. Just repeating what I've read here.
Scott
Troll! '99 BMW 328i
Posts: 107 |
OK, Great!
I think I can do that. I ask the auto parts store for a Central Timing Module (CTM)? Do you know which of the chains carry it?
Posts: 44 |
Scott
Ditto...I gave up trying to fish mine out of the rear pass door pillar.
1999 Ford Contour Lx, 2.5L V6 ATX, 145,000 miles
Pioneer DEH-P6400 H/U , Rockford Fosgate 351M 350 Watt Amp, Pioneer TS-W305DVC 12" Sub, Compustar 2WSS, Whelen CSP650 Strobe Pack with 6 strobes, Whelen Talon B/B LED Dash Light
Posts: 1,660 |
No, you don't need the CTM, just the door switch - the black oval thingy with the plunger sticking out of it; it's at the front of the door on the body of the car below the door strap. Do what I did - swap switches between the driver's front and pasenger's rear sides. 5 minutes with a phillips head screwdriver and you'll be all set for free.
Scott
Troll! '99 BMW 328i
Posts: 107 |
