#943540 04/30/04 03:32 PM
How much to replace clutch in v6 contour?
the dealer just quoted me $1100 ...... wow!
is this right? he said 10hrs labor plus $400 in parts
its not gone yet but i have 140k miles and was curious.
Thanks
john
John Overhiser Jr. Arlington, VT 1998 SE Contour V6 5-spd SVT Exhaust KKM Intake(removed) SVT airbox w/K&N E1 wheels
#943541 04/30/04 03:36 PM
9
with all those miles i would say replacing all those old internals and maybe droppin' some new stuff in there too like a flywheel and maybe a diff. if you race at the track or will be modding.
1999 Cougar V6 MTX SVT UIM/LIM/65mm TB, I/H/E, Fidanza/SPEC III/Torsen, Koni/GC's, 19" Icon wheels w/ Pirelli rubber, NX Wet Kit
#943542 04/30/04 04:39 PM
You might find independent shops doing it for cheaper, but the
10hrs labor and $3-400 parts cost (for a clutch kit) are close enough to the truth.
Tiv
#943543 04/30/04 07:00 PM
Just find a good shop as said and they'll do it for less.
Ford's quote is always $1100 for a clutch job. Plus I never like the work any dealer has ever done. So I do it myself, or use a speed shop if I can't.
99 Cougar V6 MTX...Plenty of mods My best mod thus far: Trans: Brand New MTX-75 with B1 gear set, Quaife LSD, 4.5 Final Drive, Spec Stage 1 Clutch, Spec Aluminum Flywheel...
#943544 04/30/04 08:31 PM
After looking in the labour book...I did the job myself. $400 bucks for a performance clutch. Took between 6-7 hours to do. I don't know where they get 10 from!
1998 Ford Contour GL Sport 2.5 V6 MTX in Black @ 322ks BMW 335i = Lexus IS350 in your rearview mirror
#943545 04/30/04 09:33 PM
6-7 hours? You must be awesome - it took me probably 10 days of work at like 2 hours per day. Do you have a lift and power tools and a torch?
IIRC it took me 2-3 hours just to get my shift rod disconnected, spent another 1-2 hours on a rounded tranny bolt, another hour on a tie rod end bolt that froze up. Then with 3 of us it was like 1 hour just to get the tranny back up and in, and them maybe another hour to put the subframe back up by myself...
97 Contour SE MTX K&N 3530, UR UDP, 19# Injectors, mystery mod, FMS wires, Fordchip.com chip, SVT: TB, Flywheel, clutch, exhaust 04 Grand Caravan SXT
#943546 05/04/04 04:20 PM
Errr we must be awesome! My dad helped me change the clutch. No bolts were seized, rounded and a torch was not needed. Yes we did have power tools and a hoist to work with. From what I remember, we had the shafts out within an hour. The only [censored] was one of the subframe bolts started turning with the nut...so we had to fight a little bit with that.
