#942964 04/29/04 11:19 PM
F
fiveoh Offline OP
F
What are the best pads, and what kind do i need for the front? I went to advanced auto and they had a few, but of course they were out. What size do I need? Thanks
98 Contour SVT: MUSTANG: 87 GT 5.0: TFS Twisted Wedge heads, TFS 1.6 Roller Rockers, Cobra 5.0 Intake, 3.73 gears, 76mm C&L MAF, JBA Headers, Moroso CAI, Steeda Tri-Ax Shifter
#942965 04/30/04 03:52 AM
This really belongs on the brake forum and a search there would get you a wealth of information as to different opinions of which brake pad is best.
Before buying anything, you should confirm which size pad you need. The catalogs are WRONG! If you have a 98.5 there is a good chance that you need the same pad as the non SVT. I suggest that you download the BAT catalog (or at least the brake portion) and study the pictures of the two different pad styles. www.batinc.net
#942966 05/03/04 12:21 AM
Once you've got your size pads figured out (even if you have to pull off a wheel to check for sure) try to contact Stazi for his quote on the pads you need.
MSDS, SHO-shop Y, custom 2.5" catback; xcal2; 63mm TB, K&N 3530; Koni struts, Aussie bar; THaines forks, Quaife, SpecII, UR fly; DMD; Nima UD pullies; Stazi brakes; f&r Pole120 mounts. Just a daily commuter car. Silver '98 SVT E0 #3159
