Posts: 7,025 |
The computer ecu is programmed to blow up your engine after you pass 164,341 miles. No exceptions!  But really.... I guess thats sorta like me asking you how old your gonna live to be? You take care of your body and health, youll live longer. You take of your engine and maintnance, it will live longer.
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 70 |
My Dad's '95 SE has over 245K. He replaced the water pump and that's it. As of last weekend it's doing something that makes me suspect the fuel pump is going. Ford's not all that great at engineering pumps it would seem.
Posts: 1,254 |
Originally posted by tiv: there's a guy on the forums (parkedcar ? IIRC) who has more than 250k on his duratec, without major problems.
Tiv
Not sure if thats a durtec, but his SVT has almost 150k. Ive put a pretty hard 60k on mine since i owned it, take care of it, it will take care of you.
Posts: 292 |
167k here...no problemos
1998 Ford Contour GL Sport 2.5 V6 MTX in Black @ 322ks
BMW 335i = Lexus IS350 in your rearview mirror
Posts: 9,602 |
Originally posted by AdrianCarrion: My Dad's '95 SE has over 245K. He replaced the water pump and that's it. As of last weekend it's doing something that makes me suspect the fuel pump is going. Ford's not all that great at engineering pumps it would seem.
Why because the fuel pump is showing signs of weakness after ~250k miles.
BTW - Ford does not make it's own parts. They contract.
The original W/P had inferior plastic used in the impeller molding. Manufacturer's fault for cutting corners most likely. Ford did change manufacturers.
Jury's out on the new impeller (new being 1999) but so far it seems a lot more durable and having light weight plastic verses steel dragging on the valvetrain is a better design idea. (Provided of course it doesn't break... )
The Duratec is an exceptionally designed engine with a few flaws added after it was designed. (you can thank Ford for that! ) The only one that is critical is the oiling issue from lack of head drainage at high rpm levels.
Beware low oil level especially when combined with long right hand sweepers.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 1,413 |
'99 CSVT 152k miles
'95 YJ
www.VFXCustom.com
PM me with anything you need done in Vinyl.
Posts: 3,718 |
Originally posted by DemonSVT: ...Beware low oil level especially when combined with long right hand sweepers.
Damn! Thought the pickup was on the right side instead of the left.
Bad advice on my part at the top, then.
JaTo
e-Tough Guy
Missouri City, TX
99 Contour SVT
#143/2760
00 Corvette Coupe
Posts: 536 |
Originally posted by beyondloadedSE: The computer ecu is programmed to blow up your engine after you pass 164,341 miles. No exceptions! But really....
THis is a joke, right?
99' SVT #811 of 2760
Born on january, 12, 1999.
"This may have been his only shot at number one, but he just sucks on so many levels that I couldnā??t even let him win a contest of suckiness."
Posts: 608 |
Originally posted by iamdickie: it was taken care except for the blood stains, (think someone got blown away in it) the dealership cleaned it up good though, except for under the arm rest, yuck.
A guy got murdered here (Saint John NB CANADA) a few years ago in a Contour.
Pic from news story:  http://nb.cbc.ca/regional/servlet/View?filename=nb_sjmurder20021217
He was up visiting from California. It turns out it was drug related.
Is this your car?
Posts: 1,246 |
Originally posted by TourDeForce: If you're aware of the oiling issues
Is there some oiling issues that I am missing here? Please share your knowledge.
