Anonymous
Unregistered
Anonymous
Unregistered
what engine life is "average' for a durtec 2.5???? when did your die? just want to check the time frame before i need to buy a new car.
Posts: 3,718 |
If you're prone to taking left-hand sweepers at high RPM's and aren't a fan of running a little extra oil in the engine (or slapping on a DMD for crank harmonic issues), not terribly long at all it seems.
Water pumps seem to fail around 50-70K, though mine looked perfect when I replaced it (at 59K). If you don't catch the temps rising on your engine, it will cook itself prematurely given this failure.
If you are aware of these issues and perform routine maintenance on the car, it should last you quite a long time. I seem to recall more than just a few people on this board that have their 2.5L Duratecs up in the 200K mile range.
I've got 76K miles on my 2.5L and it's running strong and sees redline more than a couple times a week.
If you are looking for a mathematical average, I can't help you as I don't think anyone has been keeping track of mileage on the Duratecs on this board.
JaTo
e-Tough Guy
Missouri City, TX
99 Contour SVT
#143/2760
00 Corvette Coupe
Posts: 536 |
Mine went at about 50k. I attribute to a hard first half of it's life. At that point I had her for about 1000miles. Now my tranny is gone, due to the differential. It was a FLEET car though.
99' SVT #811 of 2760
Born on january, 12, 1999.
"This may have been his only shot at number one, but he just sucks on so many levels that I couldnā??t even let him win a contest of suckiness."
Posts: 7,117 |
The Duratec should last a VERY long time. It's a tough engine. If you're aware of the oiling issues and don't abuse your car, you should be able to keep it for well over 200k miles.
Still, this seems to be a high maintenance car if you want to keep it for any length of time. Brake rotors, dash warp, TB cleanings, & misc other stuff will drive me nutz before the engine is ready to give out. Wiring (in older models) & tranny issues will likely come up while the engine is still running well also.
I love the car & plan to keep it for a long time, but I won't buy another. I'll pick up a bigger, better version of it, & remember it fondly every time I drive along twisty roads.
Anonymous
Unregistered
Anonymous
Unregistered
i have a se with an auto since 20k. it was taken care except for the blood stains, (think someone got blown away in it) the dealership cleaned it up good though, except for under the arm rest, yuck. it is an auto and i dont run the hell out of it. im going to clean the tb tongiht
Posts: 2,211 |
My SVT is still running strong on the factory waterpump with just over 77K.
I haven't had a single mechanical problem and the exterior looks brand new.
Posts: 3,045 |
82k on my 99svt and runs like a dream........zeros issues except for a check engine light that seems possesed
00 black/tan svt, #2052 of 2150, born 2/1/00
formerly known as my csvt
"Nothing in the world is more dangerous than a sincere ignorance and conscientious stupidity." -Martin Luther King, Jr.
Posts: 154 |
I have a 98 CSVT with 50,000 on it. I bought it nearly 2 years ago from CarMax with about 40,000 on it. Within the first 2 weeks the water pump blew apart and was replaced. The water pump just started leaking so I am currently getting it replaced again. The 3rd gear synchro is worn causing grinding and that is also be addressed now. Other than that the thing runs beautifully! Thank goodness I bought the CarMax warranty though.
-svtdc-
'98 E0 silver frost SVT - SOLD
Mods: DMD, Mobil 1 oil and filter (is this a mod?)
Posts: 6 |
My '00 SVT has 106,000 and I have had to replace the fuel pump, one set of plugs, and adjust the shifter linkage twice. I have used Mobil One since new. So far so good. (knocking on wood).
Justin
00 CSVT #1775
80 mustang prostreet project
01 Excursion limited
Posts: 750 |
there's a guy on the forums (parkedcar ? IIRC) who has more than 250k on his duratec, without major problems.
Tiv
