Posts: 47 |
In my 1996 contour gl how do I remove my speakers in the front doors? And also what size are they? THANKS GUYS
1995 MERCURY TRACER 1.9 A/T AC 99054 MILES BUYING CONTOUR IN MARCH FROM FRIEND IT' 1997 GS ZETECT A/T LOADED
Posts: 2,166 |
Check out Crutchfield for speakers. By selecting your car, it will show you what speakers are a direct replacement. Also, when you order from Crutchfield, they send you detailed installation instructions (with pics) specific to your car, with no need to buy anything else (all wire harnesses for headunits are included).
- Zack
WANTED: T-Red HEATED Side Mirrors
FOR SALE: 4 14" Alum Alloys and Nearly New Avid H4s Tires w/ Center Caps
2000 T-Red SVT
1995 LX V6 MTX (RIP)
Posts: 2,382 |
You'll have to remove the door panel. There are screws around the perimeter, behind the door handle (a little round clip) and in the elbow rest (pop out that plastic insert)
There's a plastic inner cover, but I don't think you have to remove it. The speakers themselves are held in right there. Just unscrew and there you go. There's a plug in the back/side holding them on you'll need to carefully undo.
Size, I'm not 100% sure on that.
"Fear is the little death."
Muadib.
Posts: 44 |
Ditto on Crutchfield.com or Sounddomain.com. They should supply directions, if not you can jsut search online for instructions. The size of the speakers are 6 x 8.
1999 Ford Contour Lx, 2.5L V6 ATX, 145,000 miles
Pioneer DEH-P6400 H/U , Rockford Fosgate 351M 350 Watt Amp, Pioneer TS-W305DVC 12" Sub, Compustar 2WSS, Whelen CSP650 Strobe Pack with 6 strobes, Whelen Talon B/B LED Dash Light
Posts: 2,725 |
Originally posted by idioticslacker: The size of the speakers are 6 x 8.
Actually it is 5x7 but I'm sure 6x8 would fit.
Posts: 44 |
6 x 8 is a size used by ford, nissan and mazda. that is the same size speaker that is in there right now, and the size iput in my car, and they fit perfectly. You can also get an adapter so you can put a 6" inch round speaker in there instead.
Posts: 123 |
6x8 will not fit just a little to big. the mounting holes will be off too
Posts: 4,714 |
The Pioneer 6x8's I bought were a direct drop-in. No drilling or cutting whatsoever.
http://www.sounddomain.com/sku/PIOTSA6857
Beer is my Gatorade.
Hooray Beer.
'98 "Sport" Pacific Green
'98 E0 SVT Silver Frost
Pictures
Posts: 2,203 |
My Infiniti 6 x 9's fit in with just drilling new mounting holes in the metal, then using slightly longer than stock, self taping screws. Easy install and well worth the time and effort, considering the speakers were a freebie, and they sound so much better than stock. Pretty sure I am gonna put them in back and get something in circle diameter for a better sound though.
Posts: 10 |
I put 5x7's in wife's 95 mystique and they were not quite right but a pair of 6x8's fit perfectly. Also has ford used both 5x7's and 6x8's.
