My daughter has a 1998 Contour LE Sports Sedan, 104,000 mi.
Whenever it rains, the headlights come on and you cannot turn them off. This even happens when the car is sitting in the driveway with nobody in it, engine off, all switches off, door locked. If it rains and the lights come on, no matter what you do with the switches, they will not turn off!
To keep from draining the battery when they come on, you have to pop the hood, remove the fuse box cover, and pull the middle relay out that turns on the lights. Leave it out for a few minutes and you can plug it back in and the lights will stay off. Relay has been replaced - twice.
We have left for the weekend leaving the car behind. If it rains while we are gone, the battery is invariably dead. When you plug the battery charger in, you will see that the headlights are on.
We have a friend with an identical model, this happens to his car sometimes even when it is in the garage. If it rains, his lights come on.
Does the Contour have a sensor that turns the lights on while raining for safety reasons?
My daughter thinks it is possessed.
- Regards;
MTOBryan
