#75316 04/29/01 02:01 AM
aight heres what i got:
2 Boston Ac. 3.5's up front (remember this is an Olds)
2 Kenwood Excelon 6x9's in the rear deck
I was powering these four with a 4x65 watt US Accoustics amp.
The other day at work i was bored, and one of my channels was cutting out a bit i thought, so i was fooling around with the faders and balance on the Aiwa cd-mp3. first i played the front left, then front right, then rear right and hollllly ****e what the hell happened. there was so much bass i started laughing. how could this be? so i tried the rear left 6x9 and wow there it was again! then i played just the rears, and it wasnt so impressive...
this is amazing to me, because i had never done this before. I always had the amp powering all 4 speakers at once. When you'd crank it, the bass would distort. I guess by isolating one speaker at a time, the amp could put all its power there, and my 6x9s sounded like a whole new pair of speakers!!
Well since my Infinity perfect 12.1 is out for warranty, I took the 360 PPI 2 channel that I used to power that and hooked it up to the rear deck speakers. Man those things thump! I couldnt believe it! They hit SOOO loud and SOOOO deep without distorting (25 hz) its insane.
So looks like im in the market for a new amp, cause when the sub comes back, the PPI will go back to powering that.
Peace, jake
1994 Oldsmobile Cutlass Cierra 2.2
1995 Duratec MTX GL R.I.P.
http://www.bags-of-funk.com
#75317 04/30/01 02:29 PM
Peace, jake
You sure you don't have your speakers hooked up out of phase? I'd experiment by swapping the (-) and (+) to be sure.
This is exactly what happened when I hooked up a pair of subs out of phase. Together, they'd sound like crap. But, if I faded to right or left, the single sub would sound great. Swapped the (+)/(-) on one of the subs, problem solved.
1999 SVT #900/2760
Born on 1-20-99
Silver Frost/Midnight Blue
A few aesthetic and audio mods
#75318 04/30/01 03:00 PM
I second Cthomp's thoughts. give it a try and see what happens. The amps also could be the culprit but the phase issue is easy to test and much cheaper than a new amp.
#75319 04/30/01 04:12 PM
Another question for ya, what guage power and ground wires are you running?
If you've got a multi-amp system with high guage power and ground cables, it could be simply that the amp is not getting enough juice.
1999 SVT #900/2760
Born on 1-20-99
#75320 05/01/01 05:52 PM
Cool website Jake. LOL
Tropic Green '00 SVT
#665 of 2150
Moderated by  dnewma04_dup1
