#11025 04/16/02 02:42 AM
Some CSVT owners would like to walk away from the noisy but otherwise excellent BFG KDW 215/50/16 tires. There is however a confusion about using the wider 225/50/16 tires. Some owners claim that these will fit without rubbing. Others object to that.
Luke@Tirerack sums it this way: "I don't think the 225's will fit on most Contours. I have seen some minor variations on a few cars that does allow the 225's to work but, not on many cars. The proper width would be a 215."
Luke is probably (?) referring to the suspension mods which would create those variations. It also seems that rubbing occurs with the 225's installed on the 1998 E0 CSVT stock wheels.
Let us then ask the more specific question: Is there any rubbing with the 225/50/16 tires installed on the 1999 CSVT with STOCK WHEELS AND SUSPENSION?
Your input (and Luke's opinion of course) would be greatly appreciated since I am replacing my stock tires in a couple of days.
(Thanks to Mike Delange for his reply in the Wheels and Tires forum)
Captain Bart
1999 Black/Midnight Blue SVT
#1949/2760
N
N
I have the BFG KDWS 225/50ZR/16 with no problems on my stock rims; they have better tread than the stock ones (KDW vs KDWS). I can chirp in third if i'm aggressive laugh
SVT EMBLEM MOD HERE
:::96:C:LX:::
Black 2.5L ATX "my beater" - Shaved ? badgeless ? SE rocker panels
:::99:SVT:C::: #2566 of 2760
T-RED/TAN "the bitçh" Brullen Cat-back w/ 3.5" angle-cut tips ? BAT European Suspension ? AFE Filter ? CnL 73mm MAF ? Diablosport Chip :MNQ3: ? Mirko front spilter ? Apexi SAFC (i'm scared to install! anyone in Norcal wanna help me?)
..::nyceboicreations.com::..
email:junkmail@nyceboicreations.com
Check my sig!
Stock suspension and rims!
-Andy
Andy Watson
'99 Silver SVT #2397| DOB 07/29/99
Graci!
American Iron Shoot Out - Event Promoter!
Check it out, we need your input!
Www Dot American Iron Shoot Out Dot Com
1
1
Heck, I have the 225-50-16 Firehawk SZ50EP's as well. But, I'm also lowered with Koni's and Eibachs and don't rub!
F
F
Fulda Extremo 225/50/16's lowered with Leda Sport Springs. Rubbed a hole in one of the rear fender liners, but since that happened, it doesn't rub anymore wink Fronts rub occasionally with the wheel turned a certain way and with the suspension loaded when I hit a bump, but it rarely happens.
Of couse my car is a 98, and they revised the fender liners in 99. It really depends on the tire, since different types of tires of the same size will vary slightly.
Its your call I guess. The 225's really do fill up the fenders much better than anything else. If I had it to do agian, I would still get them.
Speed kills, but it beats going slow!
Simon Langley
Black 98 SVT EO (#2119 of 6535)
269.3 FWHP, 195.4 TQ
14.123 @ 97.36
All go, and no show!
Vortech, Quaife, Driveshaft Shop Stage II axles, Magnecore Wires, Custom True Dual Exhaust.
CDW-27 1/4 Mile Registry
W
W
You have to realize that different manufacturers measure their tire tread width differently than others. (Example: Bridgestone... contact patch, Good Year... from tread groove to tread groove (that wraps around to the side wall a little)) I'm not saying that those manufacturers measure their tires that way, but I'll tell you what... different brand tires are measured totaly differently.
