Few questions for you:
How long have you had the car? How long has it been doing this? How long does it run for? Does it run smooth or really ruff after you take the key out? Does everything inside the car shut off normally once the key is out?
Reason I ask all of this is that if you are new to teh car and the old owner had a remote start system or turbo timer the car will stay running for a set amount of time. If it is a remote start system look for a little switch somewhere, if it is left on it will keep the car running for the set time period.
HTH
1999 Ford Contour Lx, 2.5L V6 ATX, 145,000 miles
Pioneer DEH-P6400 H/U , Rockford Fosgate 351M 350 Watt Amp, Pioneer TS-W305DVC 12" Sub, Compustar 2WSS, Whelen CSP650 Strobe Pack with 6 strobes, Whelen Talon B/B LED Dash Light
