This isn't my car, but I thought I'd ask here because you guys obviously know these cars a lot better then I would. My mom just got a 1995 Contour V6 Auto with about 172,000 kms on the odometer. When first starting the car up, it idles fine, around 600rpm. It goes into gear fine and doesn't die or anything. When accelerating between 1000 and 3000rpm, there is a severe hesitation, to the point that the car almost doesn't accelerate anymore. After 3000rpm the car accelerates normally. The problem becomes less severe once the car has reached the proper operating temperature, although the hesitating is still present. The check engine light is on, which leads me to believe its an ignition problem.
Do you guys have any thoughts? I noticed that this car uses coil-packs, do these have a certain life time? What about spark plugs?
And more importantly, do I need to remove the upper intake manifold to change the spark plugs?
Thanks guys, I really appreciate the help
