#938512 04/25/04 02:58 AM
Jethro Offline OP
I was just quoted $18 a piece for NGK Laser plugs, $18 each canadian that is. But still, wow! Is there any other options?
#938513 04/25/04 03:08 AM
N
N
Did you look into getting Motorcraft or Autolite? Heck of a lot cheaper, and would probably last longer.
'95 Mystique ATX I4 2.0 134,000mi '96 Contour MTX I4 2.0 36,000mi My Rides
#938514 04/25/04 05:46 PM
W
W
Do the search thing, as the general opinion is to use only Ford Plugs and you will have less problems....
Sometimes saving money doesn't....
2012 Lotus Evora --------- 95 Mystique MTX - GONE 395,000 Kms --------- Both Zetecs '97 Contour Mtx - stock - GONE
#938515 04/25/04 05:58 PM
Autolite=same thing as motorcraft but cheaper.
#938516 04/26/04 03:01 AM
I got Motorcraft's in my engine, more dependable than those POS's Champion Platinums i had in there
Former owner of a 1995 Ford Contour GL w/ 2.0L ATX Proud owner of a 2005 Ford Taurus SE 3.0L V6 Vulcan --Looking for Commodore stuff (Drives, Units, Amiga, games, etc)If anyone has any of this laying around and wants it gone, lemme know --
#938517 04/26/04 04:06 AM
I just replaced my plugs and wires in my late 98 Zetec. A 95 to early 98 may differ...
I used Autolite Platinum Pro APP5364. The Platinum Pro are double platinums. They were about $3.50 (US) each.
I think a lot of people used to use Autolite APP5344 in the Zetec. But, I think Autolite is discontinuing the APP5344 and replacing it with the APP5364.
Two of the cylinders on a Zetec require double platinum. The other two cylinders can use single platinum plugs. The Zetec engine comes from Ford with 2 double platimum and 2 single platinum. Instead of using double platinums in all cylinders, Ford only used them in the two cylinders that needed them. I think this was Ford's way of saving a couple bucks per vehicle.
If you use double platinum plugs in all cylinders you will be ok. I used the double platinum in all 4 cylinders.
For wires I used Borg Warner at $25 per set. The Ford dealer wanted something like $65.
My car runs fine with the new plugs and wires.
Reference
APP5364 - Autolite Platinum Pro. - Double Platinum - Platinum on electrode and firing tip.
AP5364 - Autolite Platinum - Single Platinum - Platinum on firing tip only.
Plug Torque - 132 in-lbs (11 ft-lbs)
Gap - .050 inch
98 Contour SE
ATX, Zetec
91,500 Miles
#938518 04/26/04 04:19 AM
I use the 5344,, though when I change them again this summer, may end up with the 5364 depending on what the stores have available.
#938519 06/28/05 04:17 AM
I can understand the price point being high but I also had to bite it on this one. I just recently put in some NGK plugs and they were worth every penny. As soon as I put them in you could feel how well they seated in, a perfect snug fit. Besides sometimes you need to treat your car and it will probly give you a thrill back.
1998 Contour SVT
1992 SHO
#938520 07/04/05 04:07 AM
H
H
Hey, what a coincidence! I was just about to go pick up a set of NGK's I ordered at Advance. They were less than $10 apiece(but not much) and everyone I've asked says they are fantastic. However, my uncle told me for plugs on a budget, Motorcraft makes some of the best on the market. I've been running some Autolite double plats, and they seem to be doing ok. Nothing like the crazy power loss I suffered from using bosch equipment. Don't buy Bosch plugs and wires. Very poor performing equipment compared to stock.
#938521 07/04/05 04:53 AM
autolite = motorcraft For cars that aren't FI'd or heavily modded, there is no reason to spend a lotta money on plugs. Autolite or motorcraft double plats will work fine.
