Alucard Offline OP
sup everyone
i was thinking about going with the Falken Torque 5 rims in 18x7 but im going for show so i thinking about going to
19x7.5 4x100 42 with Toyo Proxes 4 225/35/ZR19 300 AA A W 88
Here is the link to the tire
http://www.1010tires.com/tire.asp?tirebrand=Toyo&tiremodel=Proxes+4
and here is the link to the wheels
http://www.falkentire.com/wheels/tq5_infopg.htm
my question is how much can i lower the car with the 19's and what all if anything is required to put those rims with those tires
Ok, first: Our bolt pattern is 4x108, the wheel won't fit period. I've heard of 18's rubbing, so 19's is pretty risky. I don't recall anyone running 19's, but hey, give it a shot if you want to risk it. Use this to get a tire size close to the stock size. you should have a sticker on the door jam of your car to tell you the correct size, if not, ask. I know my '99 Sport is 205/60R15 and SVT are usually 215/50R16. Your probably safer going with 18's. Thats my input.
I run 215/35-19s as do several other CEGers.
I would highly recommend the following:
> 225/35-19 - the 215s just don't provide enough width. Given how thin the tires are, a wider tire for rim protection IMHO is a must.
> Roll the fenders. Depending on your drop, a must or you will damage up your tires, bad.
> Camber kit - or you will get very bad uneven tire wear (ask Antonio)
> IMHO, unless you have another car to use as a daily driver, 19s are too big - you will bend rims (ask Antonio)
Cons:
> Tire selection in 19s is very limited in comparison to 17s or even 18s
> Tire prices are ridiculous in that size
> The bigger you go, the more performance you lose
HTH
Capitol CEG Classifieds Make an offer! 2005 GTO IBM - 337hp/336tq
Moderated by  1314_dup1
