#936625 04/22/04 10:53 PM
Is there any sort of "bench test" for a DPFE to determine if it's functioning correctly? I grabbed a couple at the junkyard today - thought it would be nice to verify if they're good. The two I grabbed both have a metal case. Is that OE for a '95, or are these replacements?
Thanks....
#936626 04/22/04 11:18 PM
#936627 04/23/04 07:45 PM
The metal units are I believe original units. The new units are a type of plastic. BUT here's my story. I changed my unit and it was not the problem. The problem was that the Exhaust Gas Return channel from the EGR valve to the air intake plenum was blocked. I cleaned it out and spent $7.00 ojn a new gasket and fixed the problem. I think the engine code was PO302 or Po 304.You should get a check engine light if either is acting up.
#936628 04/23/04 11:22 PM
the engine code for the blocked up passage behind the
throttle body is a code 401 on the 96 contour.. and the original dpfe is silver metal case.... the new replacement ones are black plastic....
hope this helps. and also does anyone know how to test the
dpfe other than changing them out???????????
#936629 04/24/04 08:10 AM
E
E
How would the car drive if the sensor is bad?
· Jon Miconi · Coming Soon! · 01 Cougar · 98 V70R
#936630 04/24/04 06:09 PM
You might not notice it at all. EGR is implemented primarily as a means of reducing NOX output. Faulure of EGR generally isn't noticeable except to the "tail-pipe sniffer".
#936631 04/28/04 03:49 AM
3
3
just took my 00 contour to the dealer for the check engine light and they said it is the DPFE sensor and it will cost $165 installed to fix it. is this an easy do it yourself fix? or should i drop the big $$$ (not to mechanical)
#936632 04/28/04 05:05 AM
WTF is the DPFE? I should know this, but I don't...at all
#936633 04/28/04 08:31 AM
The Differential Pressure Feedback EGR (sensor) measures EGR gas flow for the computer.
The EGR Vacuum Regulator controls the EGR valve for the computer.
The Exhaust Gass Recirculation valve lets controled ammounts of exhaust back to the intake.
#936634 04/28/04 11:43 AM
I didn't either until mine blew up.
90' Bright Orange Mustang 65k - 13.306@105.1 Looking for another CSVT ~Blas~
