tymeks Offline OP
Well I'm stumped. I installed my B&M short shifter tonight and before I button everything back up I do a test run through all the gears just to make sure. And sure enough I can't put it into reverse. I don't know what I did wrong. It's a pretty easy install and I can't see what could go wrong. Any help would be appreciated.
Thanks
00' RED CSVT #1806 Don't ever forget...
did you make sure the reverse lock block is pulled up and that it is facing the right direction. if you dont have the blocked turned the right way it will not provide enough clearence to pass the reverse lockout
Trollin the boards as of 9/23
Originally posted by GS474:
stock hp is never enough
tymeks Offline OP
Yeah it's not hitting the reverse lock out. It just won't let it go in reverse at all. All the other gears just fine.
take the lock out completely off and see if it works
This was just posted yesterday i think......
No Reverse
98 SVT #1652 of 6535 My SVT "If everything seems to be going well, you obviously don't know what the hell is going on."
