F
F
Greetings,
Am I supposed to be able to rotate the front wheels with the front end jacked up and the transmission in Park?
I've been trying to find the source of a rumble during cruising that worsens when the steering wheel is turned the slightest to the left. I had jacked the car up to check the bearings and found that I was able to rotate the front wheels freely!
Thanks for your help. I really enjoy this board.
Po
Po 1995 Mercury Mystique GS: Zetec 2.0L I-4, CD4E 1978 Ford Thunderbird Town Landau: 351M (5.8L V-8), FMX Coming in 2007 -- 1986 Jaguar XJ12 Sovereign: 5.3L High-Efficiency V-12, GM transmission
the tranny has an open differential
notice that when you spin one wheel that the other spins in the opposite direction!
Russell Oval Port 3L Nearly Done MTX75 w/ Homebrew Zetec FD and Torsen Complete
TGO Offline
if it's a manual...yes
if it's an automatic...no
1999 Silver Frost SVT #609 of 2760 Quaife, lightened SVT Flywheel, SPEC stage II clutch, removed resonator, k&n drop in - various other goodies too.
Park only holds the ring gear, and thus the diff case that's attached to it, from turning. But even if the diff case is held can differentiate. So, yeah, if one wheel goes forward and the other backward, that's normal. If they both still turn in the same direction, that's another issue...
Rick Barnes '66 Ford Ranchero '84 Ford EXP Turbo Coupe '88 Mazda 323 GTX '88 Mazda 323 SE/GT hybrid '93 Ford Aerostar XLT AWD '99 Ford Contour SVT
