#933809 04/19/04 11:00 PM
I have an SVT Contour, and I was wondering why the revs fall so slowly in between first and second gear. This is especially noticeable during a moderately hard acceleration.
Red 2000 SVT Contour. Can you say "factory freak"?
#933810 04/19/04 11:04 PM
U
U
Check out the Throttle Hang Fix in the FAQ.
Welcome aboard.
Phillip Jackson `98 Mystique LS 262K+ and counting... ATX rebuilt @ 151K "This storm has broken me, my only friend!" RIP Dime
#933811 04/19/04 11:05 PM
does it idle high sometimes? you may need to do a throtle hang fix. check on the homepage under the how to scroll down to fixes and there you go.
Built April 18th 1998 #5770 of 6535 Reborn: July 11, 2004 3L and gone again 12/13/2005 new ride: 98 Silver frost SVT with all my old goodies!!!!
#933812 04/19/04 11:06 PM
Welcome aboard.
guess you beat me to it, I guess I need to learn how to type faster
#933813 04/19/04 11:15 PM
No, it idles at 750rpm. The IAC was replaced under warranty when the car wouldn't idle or start without having your foot on the accelerator.
#933814 04/20/04 02:05 PM
The 'Throttle Hang' fix will solve your problem. It will cost you a whopping $0.30 or so and will not hurt your car at all. Give it a shot. I may have a spare if you would like me to send one to you.
#933815 04/21/04 07:16 AM
Thanks for the help and for the greeting, but will the throttle hang fix void my remaining warranty? Also, how much power is lost at mid-range RPM, will my car still pass California emissions? What hole size has worked best for everyone with this mod? What "side-effects" are there of this mod? Thanks again.
#933816 04/21/04 02:52 PM
Can't say for sure, but I'd expect NO. It has nothing to do with the engine except to limit the idle air flow - which is metered air anyway.
None that I have been able to detect, but a few have 'noticed' a minimal loss of top end. I think it's only a perception & not a real loss.
Yes
Check the FAQ & the How-To. If you have an SVT start with the smallest hole. You can always make it a little bigger.
None. There was only the few that mensioned a perceived loss of power at the top end, but again I think it is not a real power loss, just a 'feeling'. BMW owners have been using this little trick since the early 80s without any known side effects. And Yes, I own an 86 BMW 325e with the fix.
