#933713 04/19/04 10:01 PM
3 questions, First the most important, On the front of the SVT Contours the chrome oval ring with the ford logo in the middle, how do you remove the black grille, i want to replace it with a silver mesh one, like the ones in the march car of the month contest. It looks like it may have to be cut out, what do i use? can it be ordered without the middle center piece, question 2, When thats all said and done whats the best way to fasten the new silver mesh grille ? question 3, I removed the lower grilles, on the front and rear of my car, whats the best way to fasten those in ? Thanks for all the help.
Morgan
98.5 CSVT Black #5707 of 6535 Born On 4-16-98 Flowmaster Exhaust BAT MAF Adapter W/ 9in K & N Knauberized B & M Short Throw Focus SVT Rims (Hopefully Tom.) Pioneer 7300 Head Unit
#933714 04/19/04 11:15 PM
2
Originally posted by BMorgn66:
3 questions, First, how do you remove the black grille:
It's installed with heat stakes, so you can use an iron to undo the stakes or just cut it. Once I was sure of what I wanted to do, I would just cut it. If you think you would ever want to undo the mod, I would learn to use a heat iron to melt the joint without destroying the grille. This way you can use epoxy to reinstall the mesh if so desired.
Can it be ordered without the middle center piece:
No
question 2, When that's all said and done whats the best way to fasten the new silver mesh grille:
I would use epoxy in the same area where the heat stakes were.
question 3, whats the best way to fasten those in:
I used a u-nut and bolt at each tap used by the factory grille.
Anthony B. Davis 2Deep2 Silver SVT 2002 IASCA SQ Ult Ama 601+ World Champion runner up 2002 SLAP dBQ Champion 2000 USAC SQ World Champion 2002 USACi SQ World Champion
#933715 04/20/04 09:12 PM
sweet dude thanks
Moderated by  WorldTour_dup1
