O
oldman Offline OP
O
95 Contour 2.0 Liter, 137,000 miles. Eng rpm drops to 500 rpm when stopped and in gear (auto trans). Problem is compounded when A/C compressor cycles on. The car has been to the dealer for this problem and they have been unable to fix it. I also had an independent look at it for a few days. The idle air control motor has been replaced/no fix. Idle problems seem to be a common complaint on this vehicle. Got tired of the Ford dealer throwing parts at the problem. Do any of you have any suggestions as to a fix? I have been driving the car with the problem for a couple of years now. Otherwise has been a decent vehicle. Thanks
Check EGR, I had similar problems..low idle then reving and stalling. Cleaned EGR and it hasnt done it yet, plus the check engine light is off, it was on for over a year. That seems to have fixed it though. I will be checking my IAC this weekend, just for the heck of it. Good luck..
Welcome
Matt
'97 Pumice Zetec Sport- 'At least its not a geo!'
How old is the timing belt? Plugs and wires?
There is a good chance that you have a vacuum leak in the
PCV hose under the exhaust manifold if the hose has never been replaced.
O
oldman Offline OP
O
Thank you both for the advice. I will look at those suggestions. Was hoping you avid FOMOCO enthusiasts would would be able to steer me in the right direction.
H
H
Where is the EGA valve on 96 Zetec?
Dean
Not sure what the EGA valve is, but the EGR valve is located near the intake manifold.
