Originally posted by Rogerm60: Are you certain that the short rubber hose between the intake and PCV valve is not leaking?
I took another look and found out that it was coming loose on one end. I had trouble with the hose previously as it had a hole in it, so I cut it shorter by an inch. Is that bad or should I replace it? I can't think of another reason why it would come off other than that.
I was having the same problem, had the pressure test done and checked out okay, finally had the maf changed $280 from ford, car now works okay for now at least it does'nt shut down anymore
