Posts: 2,725 |
For when I do get this amp and subs, I have a few questions about it?
Does it shorten the life of the alternator and battery by a lot, like will it fail soon after getting it installed?
Secondly will I be able to shut off the amp and subs and just have the speakers inside going, or will the subs be on all the time?
thanks
Posts: 735 |
Originally posted by HITMANinMI: Secondly will I be able to shut off the amp and subs and just have the speakers inside going, or will the subs be on all the time?
thanks
Not sure about the other stuff, but on my Alpine head unit, you can turn the subs on and off.
'99 Sport TropicGreen,Duratec, SVT exhaust, Brembo rotors, Ceramic pads, K&N filters(oil & air), Alpine CDM7874, Polk DB570 speakers front and rear. Fog light mod. 50% Formula One tint.
Posts: 1,359 |
If your head unit doesn't have an amp turn on/off option, your amp may have a gain adjuster that will allow you to turn it on or off or your other option (which is quite simple) would be to wire a switch up in parallel with the amp turn on lead.
98' Contour SVT
#607 of 6535
05' Mazda 6s
Audio/Visual enthusiast because it's one of the many things I went through 4 years of hell for
Posts: 54 |
Posts: 1,346 |
Originally posted by gearhead: Originally posted by HITMANinMI: Secondly will I be able to shut off the amp and subs and just have the speakers inside going, or will the subs be on all the time?
thanks
or you could just run a switch in parallel with you sub....dont know about the alternator stuff...hope not though
E1 CSVT
s/c-----x
turbo---x
3L------check
Posts: 4,639 |
if the cabin speakers are going to be run off the hu, and the sub off an amp then just wire in a switch to the remote turnon
Hugo AIM:omegazodiac
Posts: 8,301 |
Originally posted by hmouta: if the cabin speakers are going to be run off the hu, and the sub off an amp then just wire in a switch to the remote turnon
I agree, I have done several installs like that and it works great.
-Ken V.
psycho_bass@hotmail.com
Posts: 21,653 |
Since he decided not to get the stuff, I'm gonna change the topic real quick. I think I may have asked this before, but can't remember. Anyways,,, can I tap into the remote wire for my indiglo gauges to run off of it , it will of course still be connected to my amp. Does it carry enough power to run the indiglos?
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 3,076 |
A system with as little power as yours will not affect the life of the alternator. And it should have very little effect if any on the battery life. If your the type who continuously turns off your car and listens to the radio for long periods of time and drains the battery down to barely enough power to start your car....then you will hurt your battery life.
2000 SVT Black/Tan #1633/2150 (a few mods)
Alpine: CDA-9835, MRV-F540, MRD-M550
PG: TANTRUM-X 6.5 COMP all around.
Some people wear Superman pajamas. Superman wears Chuck Norris pajamas.
CEL currently: Off
Posts: 7,392 |
Originally posted by Kremithefrog: Since he decided not to get the stuff, I'm gonna change the topic real quick. I think I may have asked this before, but can't remember. Anyways,,, can I tap into the remote wire for my indiglo gauges to run off of it , it will of course still be connected to my amp. Does it carry enough power to run the indiglos?
probably not. and you'd most likely be introducing some noise into the system as well. you could do it via relay if you really wanted to though.
.....______
___|______\_____
|/-\_________/-\_|
.\_/...............\_/
