I just received my speakers for my install that I am currently in the process of performing. I've finally worked out wiring and mounting issues and started connecting everything up in the first door. I connected the crossover and then the woofer and tweeter. I turned on my HU and listened to the woofer and tweeter to make sure the terminals were hooked up + to + and - to -. I noticed when listening closely to the tweeter that it was hissing rather loudly, considering I hadn't turned up the volume much yet. I thought I got the connections switched around, and changed them, but the hissing persisted. I adjusted the balance and fader so it was only the front driver's speakers and the hissing continued, masking almost all of the sound the tweeter might otherwise be generating. I turned it up to normal listening volume and the hissing got louder, to the point where if I sat in my car with the door closed and the engine off, I know I could hear it all the time. Are my tweeters ruined? Perhaps more importantly, did my handling (which was gentle) damage them before I had even hooked them up? I would think that if that was the case, it would be impossible for them to hold up while driving.
I am going to call PE in the tomorrow and see what they have to say, but in the meantime...
