Having trouble removing front strut/spring assembly. So far I've removed the control arm, the stabilizer arm and pinch nut on knuckle but still cannot get assembly out...it won't drop low enough. Do I have to remove that lower ball joint as well? As it stands...the strut is kinked a little in the top last little bit of the knuckle mounting hole. I don't care if I wreck the old strut or spring as I'm putting new ones.
If I do have to remove the lower ball joint...is there a way to do this so that I don't destroy the rubber boot on the ball joint?
