#928765 04/14/04 05:04 PM
d c Offline OP
hi, i'm going through front tyres like theres no tomorrow and as my car has been lowered 40mm have been told that the camber has been altered, the tracking is ok and theres no wear on the suspension bushes.
anyone know of a camber adjustment kit for the zetec mondeo (contour) if so can you post a web address
danny
#928766 04/14/04 05:45 PM
Toe wears out tires, not so much camber. But excessive camber makes a toe problem wear tires out even faster. Lowering the car affects camber which affects toe. Get the toe checked and reset.
Pacific Green '96 Contour LX V6 â??98 GTP, light mods, 14.66/94 Calypso Green '92 Mustang LX coupe, 13.56/101 Crown Autocross Club 1999 Street Tire Champion, 2000/2001/2002 Street Modified Champion KCR SCCA 2002 Solo II Street Modified Champion
#928767 04/14/04 09:27 PM
Danny,
Since a 40mm drop is fairly major you probably need the camber kits. What strut/spring combo did you install to give that drop?
Check this catalogue. Cheers!
http://www.batinc.net/contour.htm
'98 LS MTX
#928768 04/15/04 04:12 AM
The camber kits that BAT sells are marketed here in the US by Specialty Products. No matter where you end up buying them, you will find their web site helpful. I understand that they are made offshore so there may well be a distributor for the same thing but possibly under a different label in other countries. Here is the URL for Specialty Products.
http://www.specprod.com/
#928769 04/15/04 07:38 PM
d c Offline OP
Originally posted by larsofvt:
Danny,
standard strut and shocks with PI springs
thanks for replying guys
#928770 04/15/04 07:41 PM
Yeah, get some struts that accomodate lowering springs and 2 camber kits and you should be good. What are PI springs? Progressive maybe?
99 SVTC, T-Red, #652/2760-12.8.1998 Mother#@%@!* did I sound abstract? I hope it sounded more confusin than that!
#928771 04/16/04 07:59 PM
d c Offline OP
will do, thanks
see here for pi springs
http://www.p-i.co.uk/
