G Stone Offline OP
I bought a used clock light bulb from a junk yard today. I tryed installing it but it still won't light up. The clock still works but no light. The bulb looks good unlike my old one. I turned it into different positions to see if it worked every which way, or there was a sweet spot, but nothing. Any tips? I'm gonna have my dad take a look at it tomorrow, hopefully its just something dumb. Just looking for advice. Thanks.
Champagne 1995 Ford Contour LX R.I.P. - 7/11/06 V6 2.5L 24v DOHC Oversized System
Z
Z
Do you have a tester to check if the bulb is good? A bulb can look just fine and not be OK.
Brad "Diva": 2004 Mazda 6s 5-door, Volcanic Red Rex: 1988 Mazda RX-7 Vert, Harbor Blue.
G Stone Offline OP
No, I don't. is there a different way I can see if its good
F
F
you are probably better off going to a dealer and spending $5 on a new bulb. At least you will know that the bulb will last.
The bulbs are probably cheaper somewhere like Advance Auto. Just take your old bulb in and compare them to the ones on the replacement bulb rack. Move the green condom from the old one to the new one and you're set.
98 Contour V6 MTX, T-Red, 150k mi. Pic SVT Dual Exhaust, KKM Intake, Donnely Mirror, Dension DMP3 Player w/80GB of MP3s, Wheelskin 95 F-150 91 Mustang GT 06 Honda Shadow Aero
Z
Z
May want to consider investing on a multimeter. This way you can check the voltage in the circuit when your lights are on (make sure you're getting a signal). And also check for continuity in the bulb. This will verify if the bulb is good or not.
- Zack WANTED: T-Red HEATED Side Mirrors FOR SALE: 4 14" Alum Alloys and Nearly New Avid H4s Tires w/ Center Caps 2000 T-Red SVT 1995 LX V6 MTX (RIP)
G Stone Offline OP
got it working. turns out the bulb WAS bad. i went to the junkyard and jacked another one from a contour, and this one worked. i didn't look closely enough at the other one. thanks for the help though.
