Posts: 2,469 |
So i recently switched to h&r's and i like the handeling alot but it still has a little too much understeer for my taste. My ? is If i switch to a bigger rear sway bar. How big can i go before i run into rear subframe prob's. I remember reading that people running the auzzie bar had to weld there rear subframe other wise it would break. But i dont remeber details. How big is a auzzie bar anyways? and who else makes a bigger rear sway bar? I also remeber hearing somewere pre 98's had bigger sway bars than a svt. Or was it reg. se's had bigger. Can someone clarefy all this confusion. And any other ideas to help reduce understeer, other than making the car stiffer than a f1 car. thanks
Posts: 3,496 |
Aussie bar = 24mm hollow
I'm running a SCA 21mm bar, supposedly hardened to that of a 22mm equivalent. No longer produced.
BAT makes a 21mm bar as well.
SVT bar = 18 or 19mm 95-97 SE Bar = 19mm
I have not torn my subrame apart but I could definitely see it happening as I would continually bend the stock brackets. When they bend the bar can move a significant amount and you get the dreaded CLUNK. Basically your bar moves the bracket and then as it unloads CRACK metal bracket slamming itself aginst the stock bracket. I think this scenario is what weakens the stock mounts and breaks em.
I upgraded to Prothane brackets and grooved bushings. I used the stock mount. I used the stock bolt on one end and then headed to the hardware store for some quality washers, bolts, and lock nuts. I placed a washer on the top, wedged bolt into the hole the stock bracket slides into and through the Prothane bracket. Placed another beefy washer and ran a nylon thread lock nut up. Tigthened it down and have been running problem free for 18+ months now. I check them ever 3-months or so to ensure its not bending and no clunk has been heard.
Its ghetto rigged but it works like a champ! Use Marine Synthetic grease (Wal-mart) $1-$2/tube on the bushings and you should be OK for squeaks as well. Non-grooved bushings dont hold the grease well. I have not autocrossed my car but I'm certainly not babying it on Mountian drives or tight corners on the street.
Perhaps the car has less flex/roll because I'm on Eibachs/Koni's and that helps prevent the stock bar from traveling as much as it would on a stock set-up.
Hope that helps!
Posts: 3,887 |
There are a few aussie bars in the classifieds for sale. You best mod the rear sway bar mounts though before installing it.
06 GMC Sierra 2500HD Dmax/ally
06 Pontiac G6 GT
05 CRF250R
FOR SALE 06 KX65 with riding gear $2700 obo
Posts: 2,469 |
I have a local muffler guy that is real good with a welder. Is this something any decent welder could do?
Posts: 3,887 |
I completely redid mine in about 2 hours. I have picks I could email you if you wanted. I modeled mine off of the ATI modded subframes
06 Pontiac G6 GT
05 CRF250R
Posts: 2,387 |
98 3.0 svt: Sold
Posts: 3,887 |
Ok here is the link to the page where I got my pics to do this mod from. ATI subframe It's from the archives and mine is almost identical. I just made my mounts longer for more strength. It's an easy mod to do for any welder
06 Pontiac G6 GT
05 CRF250R
Posts: 113 |
Woohoo, someone is viewing my pictures! Maybe this online community thing really can be a useful, collaborative effort after all.
-Kurt
50% of all people are below average.
Posts: 3,887 |
06 Pontiac G6 GT
05 CRF250R
Posts: 8 |
Fmr12B do you happen to know what kind/size of bushing/end links I need for the 24mm Aussie bar. The Aussie was already installed when I bought the car and the bushings/end links appear to be shot. I called Summit Racing today and they wanted to know sizes of each. They claimed to not know what the Aussie was.
Thanks, -ds5192
