Posts: 829 |
I searched but did not find what i was looking for... Here goes. What temp are most of you 3.0L guys running. I seem to be running at 215-220 and I feel a little anxiety about it. I am in PHX and it is blazing hot here in the summer. It is only getting to about 90 currently. I have the 180 T-Stat currently but I want to run the 160. What is the part number? Do 3.0L's typically run hotter than their 2.5L counterparts? I am using an Autometer Phantom Gauge and I am not sure how accurate it is. I am going to plug into an OBDII scanner and monitor it from the brain, then I will have an idea of its accuracy.
SVT Parts For Sale!PM Me.
2006 M6 Cyclone Gray GTO
1995 Mazda Protege Commuter Special
93 FXDWG Dyna Wide Glide
I'm A TROLL Now!~
Posts: 9,602 |
What are the fan temps set at?
My engine runs in the 170's during spirited driving.
160 T-stat.
Fans at 186 & 196 but even the primary one rarely comes on. Secondary one never does.
Temps have been in the 60's & 70's so it's not hot yet.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 2,469 |
Originally posted by DemonSVT: Fans at 186 & 196 but even the primary one rarely comes on. Secondary one never does.
So what are you doing that keeps the temps down so low? I flushed my radiator added water wetter and i had a obd laptop scanner tell me my temp was right at 200.
Posts: 9,602 |
I'm running Zerex Extreme (OAT) 40% and water 60%.
Yes some water wetter.
If you are runing the stock T-stat it does not fully open until ~192-194.
It is rated to start opening at 188. (Also it's the same one most aftermarket companies sell as a 180 t-stat  )
2000 SVT #674
Posts: 411 |
From the 3L FAQ
Stant Part# 13396 â?? 160 Degree T-Stat
-Chuck Dienzo
Black 98.5 E1 SVT
#5022 of 6535
Born on March 16, 1998
"If trees could scream, would we be so cavalier about cutting them down? We might, if they screamed all the time, for no good reason."
Posts: 1,325 |
Originally posted by dubkatz: Originally posted by DemonSVT: Fans at 186 & 196 but even the primary one rarely comes on. Secondary one never does.
with my 160 stat, regular antifreeze and watter wetter I run at 170ish most of the time like Demon. With stock stat I always hit 200 as well.
Runs a bit to the left of N on the gauge now. Since I have stock fan programming as soon as I stop moving, hit stop and go or am really on it alot it goes right to the old temp, but for the 75% of the time I'm just cruising it stays nice and cool.
thanks demon
97 Contour SE MTX
04 Grand Caravan SXT
Posts: 829 |
I got some part numbers from Autozone. They don't carry Stant T-Stats. The FailSafe number is 7200-160. Does anyone know if this is correct?
I'm A TROLL Now!~
Posts: 9,602 |
Originally posted by Rev. Po-Jay: I got some part numbers from Autozone. They don't carry Stant T-Stats. The FailSafe number is 7200-160. Does anyone know if this is correct?
Last time I checked AutoZone did not carry any thermostats for the Duratec.
Stant does not list anything but the reboxed OEM t-stat (mislabeled as a 180) when looking it up by application. DON'T look it up by application.
If you want a cooler thermostat (160 rating) run the known good stant number I figured out a while ago.
DO NOT even bother with trying a 180 t-stat. The change from stock at full open is maybe a couple degrees and that's once you actually find a manufacturer that makes a 180 and does not sell a reboxed OEM as a 180.
Also like Scott said. Without the fans changed you are at the mercy of your cooling system and fluid type & mix when "moving" slowly.
The more efficient that is (SVT radiator, OAT coolant, higher water %, water wetter type product, etc) the cooler everything runs under all conditions.
2000 SVT #674
Posts: 829 |
The Failsafe is supposedly a 160 T-stat... Hmmm. I will track down the Stant.
*Edit*
Checker is telling me that they no longer have the ability to get that part number. Where else can I get one?
I'm A TROLL Now!~
Posts: 1,325 |
Originally posted by Rev. Po-Jay: The Failsafe is supposedly a 160 T-stat... Hmmm. I will track down the Stant. *Edit* Checker is telling me that they no longer have the ability to get that part number. Where else can I get one?
http://www.brothersperformance.com/shop/mustang/sta13396.html
or
http://www.partsamerica.com/PartDetails.asp?SourceArea=&SourcePage=SEARCHRESULTS&MfrCode=STN&MfrPartNumber=13396
97 Contour SE MTX
