#927645 04/13/04 06:57 PM
Ok, I just got my car bock from the shop for body work, and a new radiator install.
And the car now has like 100 CODES...
The car is misfiring horribly in the rear bank, cylinders 4-5-6. I ran my OBD2 scanner, and got codes for:
-Misfires in cylinders 4,5, and 6
-Random misifres
-Rich and lean in the rear bank
-P0340 Cam positoon sensor Circuit malfunction
-and my front upper O2 is dying...
All was fine, the shop did no mechanical work.
WHAT THE FU*K DO I DO NOW.
HELP ME PLEASE...
99 Cougar V6 MTX...Plenty of mods My best mod thus far: Trans: Brand New MTX-75 with B1 gear set, Quaife LSD, 4.5 Final Drive, Spec Stage 1 Clutch, Spec Aluminum Flywheel...
take that [censored] back, they did something wrong if when you took it in it had none of these problems and when you got it back it suddenly hass all these problems. those kinda things dont happen randomly if i was you i would take it back today
98.5 Black SE ATX S&B filter, SVT MAF, optimized SVT TB, mesh grille, removed orange reflectors, painted rear reflector, gutted pre-cats, optimized SVT LIM, 19lb injectors, resonator removed cant afford an svt but lookin for 1 in nc
Odds are, when they were doing work, they removed the plug wires and didn't put them in right. That is what is most likely causing the misfire.
I would call the shop back and make them fix it.
2003 Sonic Blue SVT Cobra Coupe 2003 RedFire SVT Cobra Convertable 2005 Dark Toreador Red F150 XLT 4x4 2000 Black SVT Contour - Beater
If mmars is right, I'd check that out before I went driving the car again...
I hope it's an easy fix.
Derek Scion xB 5-spd Previous: 2000 Silver Frost SVT Please share the road with cyclists.
U
U
cam sensor could just be unpluged too. Do some looking around under the hood. Look for anything unpluged or out of place.
Good luck.
Phillip Jackson `98 Mystique LS 262K+ and counting... ATX rebuilt @ 151K "This storm has broken me, my only friend!" RIP Dime
Good luck.
That happened on mine. Standing in front of your car, it's a the black plastic piece that is plugged together (or should be) that is just to the left of the engine block. It's basically right up next to it if I remember correctly, closer towards the front. Make sure your engine isn't hot
'03 SRT-4 50 trim turbo + support
