Posts: 7,117 |
Originally posted by btrautman: If you don't feel comfortable rebuilding your own trans, I'd recommend you purchase rebuild unit from phoenix transmissions. You can get a rebuild for 800 dollars plus 100 or so for shipping.......
Good call. I think that's the heavy duty transmission too, with the upgraded parts for the Escape. All the details will be on the web site.
Posts: 1,176 |
Posts: 1,176 |
I just finished rebuilding my atx. There are MANY things that can go wrong to cause you problems. When I rebuilt mine, I found crack inside case, cracked/leaking direct housing, oil pump blowout, valve body worn, clutches/steels worn beyond specs, reverse drum leaking. I pretty much replaced everything that I felt was even remotely in question, including solonoid pack, shift correction kit, tss, vss and manual level control switch, tc, bearings....
Troubleshooting these atx is also kinda complicated...I thought Unisys was right on track until you revealed that you actually took a line pressure test! I haven't seen too many people know about a line pressure test let alone perform one!
Regards, Bob
Posts: 4 |
I read all this and I feel like crying! I don't have the know-how or $2K + to drop into a tranny rebuild. I guess I'll drive her till she dies! Road-side burrials are the best kind!
Kev
Posts: 3,944 |
Originally posted by btrautman: Troubleshooting these atx is also kinda complicated...I thought Unisys was right on track until you revealed that you actually took a line pressure test! I haven't seen too many people know about a line pressure test let alone perform one!
Regards, Bob
Posted : 4/11
Originally posted by lgy: I check the line pressure, 65PSI for P/N/R and 45PSI for D/2/1
Posted : 4/11
Originally posted by lgy: Today, I did the line presure test, they seem OK even a little bit low but still within the normal range.
Posted : 4/22
Originally posted by lgy: Now I am thinking probably it is the oil pump because the line presuure is in the low side.
PARK, NEUTRAL - 64 - 76 REVERSE - 64 - 76 DRIVE - 45 - 63 SECOND - " " FIRST - " "
How and why did I miss this?
Igy, man I am so sorry. Really I am! I should have known that if your pressure was that low, although border line, once your TC stalls - all hell will break loose.
This is why I am beating myself up here...
It is a known fact that the CD4E is very sensitive to line pressure and changes in line pressure. It is its second short fall. Knowing this, along with the fact that "I" missed this information that Igy posted... THREE TIMES none the less, I should have mentioned the pump to begin with.
Igy, my deepest apologizes go out to you. I feel like I have let you and many others down. As a moderator of this forum, I should have paid more attention to the thread and seen this, but I apparently didn't and missed it.
Now that that is out of the way, may I suggest this. It might be worth looking into. I'm not sure how much a pump is, right off hand, but these pump gears just might help you out since you have put so much into it already.
Phillip Jackson
`98 Mystique LS
262K+ and counting...
ATX rebuilt @ 151K
Posts: 34 |
Thank you unisys12 for your kind replies everytime. Actually your replies are so helpful. When people post questions here, they really want replies.
Today, I did further test. Here is the update.
First I drove the car with the O/D off on free way at 85MPH. I monitor the TCC duty cycle. It was 100% lock. The slip is also very small, around 3-8RPM. The turbine speed is around 4100RPM.
Then I went to a highway, let the O/D on. I noticed that the TCC is locked from 35MPH to 50MPH although not 100%. The turbine speed is around 2000RPM. However it is unlocked once I reach beyond 50MPH, and the techometer jumped 200-300RPM. After a while, the failsafe mode reported. Once the tranny goes into failsafe mode, the TCC will never lock again.
Now I am 80% sure it is the pump problem. There must be excessive leaking inside the pump. When I drove the car with O/D off, the high TSS rpm may compensate the leaking. But when I drove with O/D on, the lower TSS rpm cannot compensate the leaking which may cause the line pressure drop and then cause excessive TCC slipping. The PCM monitors the excessive slipping and unlock the TCC, this further causes the failsafe mode and reports P0741 code.
There is 10% possiblity that something is stuck between the VB and TC. But this possiblity can be minimized by observing that the tranny slipping problem becomes worse after I replaced the TC and Mobil one ATF which has smaller size molecules. The small size molecule is easy to pass though but also causes big leaking problem. In this sense, I don't recommend people to use Mobil One ATF or engine oil for high millage cars.
Another 10% possiblity is that there is leaking between VB and TC. But this possibility can be also minimized by observing that the TCC locks well in third gear.
It's time for my next project. I need to drop the tranny again, and replace the pump.
A good scanner is really helpful to diagnose problems. I recently bought the Alex version OBD-II through group buy. It can monitor more than 170 signals. I really like it.
97 LX V6 2.5L
Posts: 3,944 |
Originally posted by lgy: Thank you unisys12 for your kind replies everytime. Actually your replies are so helpful. When people post questions here, they really want replies.
Thanks. And with the information that you have just provided... I really need to update my site.
Phillip Jackson
`98 Mystique LS
ATX rebuilt @ 151K
Posts: 34 |
I wish I did it at the beginning. Look at what I have spent in trying to fix this tranny.
$100: Tranny Jack $300: VB (rebuilt) $150: TC $100: Solenoid $100: ATF $30: TSS $250: Pump (still looking for it)
Total $1030 and my time include not only the labor but also searching and study on this tranny.
97 LX V6 2.5L
Posts: 1,176 |
Instead of of an entire new pump, the pump gears from sonnax looked interesting..Also there is a revised pump backing plate and revised pump gaskets that you need to use....You can get these from Transtar...... The revised plate and gaskets prevent pump blowout....
You can get a new pump from Jim at Signature Ford for around 190...
Posts: 7,117 |
Originally posted by KevinC: I read all this and I feel like crying! I don't have the know-how or $2K + to drop into a tranny rebuild. I guess I'll drive her till she dies! Road-side burrials are the best kind!
Kev
Where do you live? What year, engine, mileage is your Contique??
If you abandon it near me, I might tow it away for free...
