Page 1 of 3 1 2 3
#925519 04/11/04 04:27 AM
Q
Q
Well it is a sad story but I will make it short my diamond forged pistons were stolen out of my car I was in the process of moving and they were just sitting in my back seat.
This whole thing really set me back because of my lack of funds now, and the time it takes to make another set of pistons, so I decided to wait, not cut any corners and build a really nasty 3L that will hold a lot of boost.
Well obviously to make the power I want to make I need some pistons with good rings to hold 12-15 psi. I could buy another set of Diamond 9:1 comp ratio pistons for around $700 or... I could get a set from Duratecperomance.com for $500 (Only if I buy the forged rods too, which I am seriously considering) And these pistons are 8.5:1 comp ratio.
Here is where it gets a little smokey for me. I bought the heads for my 3L from Warmonger and he had severly ported these heads, which I belive will drop my comp ratio a little.
Please give me some useful input on the pros. and cons of my setup with the different comp ratios. And if you don't know anything about my setup, click the link in my sig. Thank you guys
-Jeff-
1998 Black SVT Morette Twin headlight conversion Street flight turbo kit collecting dust! Rebuilding my 3.0L check it out
#925520 04/11/04 05:34 AM
Tom's ported 2.5L heads on a 3L engine with pistons designed for a 8.5CR would be:
~8.85 to 1
That would be a good compression ratio for a project running high boost and the appropriate compressor map.
#925521 04/11/04 03:01 PM
Q
Q
For some reason I was under the impresion that those heads would lower my comp ratio... (For people who don't know they are 2.5L heads fitted with the 3L valves ported on the intake and exhaust sides)
Demon: What you saying is that I should go with the 8.5:1 CR pistons, and with that compresion ratio how much boost do you estimate it would take to put down 330-350whp and 320-330whtq? And with that low of CR I could run more boost due to less chance of detontation, correct? Thanks
Anyone else have any opions? Any info is welcomed
-Jeff-
#925522 04/11/04 05:02 PM
The lower the compression the more boost it takes to make the same power. You have 2.5 heads on a 3.0. It should have been 11.x compression but was dropped to 10.1 or .2 IIRC. So you will actually added a couple of tenths to the final compression of the pistons.
You don't need to forged everything with the goals you have set. It would just be a safety precaution. You could just use a straight 3.0 and run less boost.
2001 Lincoln LS8 1994 Lexus GS300
#925523 04/11/04 06:31 PM
Q
Q
I would like to go all forged, and make upwards around 400whp that would be great!. But also I want to keep some traction for the street, and keep the boost down a little. I would just like to build it bulletproof incase I do want to boost that high. Does that make sense? How much power do you think I could handle with the stock 3L block, Forged pistons and rods with the stock crankshaft? Just out of curiosity.
-Jeff-
#925524 04/11/04 10:33 PM
I'm no compression guru, but I know these engines perform well because they have a relatively high CR.
If you're going to have a "street" and "track" tune (i.e. less and more boost respectively) I would think something around the 9.0 CR would keep "street" drivability at a comfortable level.
Derek Scion xB 5-spd Previous: 2000 Silver Frost SVT Please share the road with cyclists.
#925525 04/12/04 05:06 AM
13-15psi on a 60-1 trim.
Torque should be quite good!
You would want a two stage boost controller.
#925526 04/12/04 03:34 PM
Q
Q
You make a very good point, But then my question is what is the benifit to runnig a lower compresion ratio? If I chose to go that route I could just throw in those sealed power pistons that tom gave me and, what 8psi? would prolly be the max boost I would run. And I would make simaliar HP/TQ numbers as I stated above?
If I go all forged and run 13psi with the lower compresion ratio, what do I stand to gain from that?
By the way Demon, I have got the Turbo XS dual satge boost controller sittin right next to me... lol... I can't wait!
Thanks guys,
-Jeff-
#925527 04/12/04 09:09 PM
That remains to be proven.
However seeing the outstanding numbers a basic 3L oval port made on 10psi one would be hard pressed to make "enough" more power to show up "at the wheels in real driving" to show a big difference.
Dyno queen - Hell yes!
Drag queen - perhaps.
Real world putting the power to the ground through our platform without wasting it in wheel spin??? That remains to be proven.
However it is most definitely possible and pretty likely!
Just how much Money will it take to make it "reality" though??? Then compare it to what you get for little cost "comparatively"
Our engine design is very good at being very resistant to detonation. (I.E. 13+psi from a T28 on 10.31 CR!)
Tom ran ~10psi on both his 10.25-10.3CR 3L and 10.1CR oval port 3L
Now for cams.
Stock oval port cams for 5-9psi. (mad early TQ hump & they can't support high rpm anyway)
SVT cams for 9psi and above. (nice TQ, FLAT TQ, KILLER HP above 5000rpm)
If I were to build an engine that had plans to be boosted I would build it exactly like I did.
#925528 04/12/04 10:30 PM
Hmmm...
1999 Blk/Tan CSVT #654 - SOLD 2003 Suzuki SV650s
Page 1 of 3 1 2 3
